Введение
This guide will show you how to replace the computer's display screen. Replacing the display screen is necessary when the screen won't turn on or it's cracked. Before conducting our steps, please make sure your computer is powered off.
Выберете то, что вам нужно
Open the laptop and unscrew each of the screws that are in the corners of the screen using a Phillips #1 screwdriver.
Using a metal spudger, insert the spudger around the edges and the bottom to detach the frame from the screen.
Using a Phillips #1 screwdriver, unscrew all of the screws on the sides of the screen.
