Введение
This guide will help you replace/upgrade the RAM on your Toshiba Satellite Radius P55W-B5112.
Выберете то, что вам нужно
Unplug your laptop from any source of power.
Lay your laptop on a soft, clean surface as shown.
Using the metal spudger, remove the two rubber grips on the bottom face of the laptop, located closest to the hinge.
Remove the ten 5mm Phillips #0 screws that secure the back plate to the computer.
Starting on the edge that is opposite the hinge, use the plastic opening tools to pry the back plate away from the computer.
Loosen the three non-hinge edges.
Leave a plastic opening tool in each corner to ensure that one side does not snap closed before you are done opening the others.
To loosen the back plate, lift it slightly and gently pull it away from the hinge.
Flip the back plate open towards the power button, but be sure to not pull on the ribbon cable that connects the back plate to the motherboard.
Use a plastic opening tool to detach the side of the ribbon cable connected to the computer by prying up gently on the small black lever at the point of attachment.
Use a plastic opening tool to lift the side of the battery that is closest to the long edge of the computer.
As you are pulling the battery away from the computer, unplug it from the side closest to the short edge of the computer.
Use a spudger to gently pry up the plastic brackets holding on each RAM drive. The long edges of each drive furthest from one another should pop up at an angle.
Remove each RAM drive by pulling at an upwards angle in the direction of its free edge.
3 участников успешно повторили данное руководство.
2 Комментариев
Hola estimado, quiera saber el código de la pieza conector hdd sata para Toshiba satellite P55W-B5112
Ya done great, bro!!!! Kudos and many thanks!!!
