Введение
The battery is the power source for your laptop. If defective, this guide will instruct you on how to remove and replace your battery.
Выберете то, что вам нужно
Remove the two rubber feet closest to the hinge with a plastic opening tool.
Carefully lift open the cover.
Remove the attached purple ribbon cable underneath the cover.
3 участников успешно повторили данное руководство.
