Введение
If you find that your laptop is having difficulty keeping any charge, or that it will not turn on or function well without being plugged into the wall charger, it may be time to replace the battery.
This guide will show you how to replace the battery on a Toshiba Satellite S55t-A5389 laptop.
Выберете то, что вам нужно
Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
Remove the four 5mm Phillips #0 screws from the battery.
Unplug the battery from the motherboard.
Remove the battery from the laptop.
2 человек успешно провели ремонт по этому руководству.
