Введение
If your laptop no longer runs as well as it did, and has become slow, unresponsive, or does not power on. You're processor may be at fault and replacing it could be an option. However before this is done, be sure to check your laptop for any viruses, or any other issues that it may have.
Выберете то, что вам нужно
Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
Remove the four 5mm Phillips #0 screws from the battery.
Unplug the battery from the motherboard.
Remove the battery from the laptop.
Remove the four 5mm Phillips #0 screws from the heat pipe.
Remove the fan and heat pipe from the laptop.
Rotate the lock 90 degrees using a Torx T8 in order to remove the processor.
3 человек успешно провели ремонт по этому руководству.
