Введение
If your Toshiba S55t-C5225 can no longer hold a charge, it most likely has a dead battery and will require a battery replacement. A working battery provides power to your laptop.
Make sure to turn off your device before starting the battery replacement guide.
Выберете то, что вам нужно
Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
2 человек успешно провели ремонт по этому руководству.
