Введение
The battery on the Satellite is relatively small and after a year or so it may no longer hold a full charge. Replacing the battery will allow you to retain the full functional life.
Turn the laptop over.
Slide back the left lock, and you should hear a click when it is successfully locked back in.
Rotate the laptop 180 degrees so that the battery is near you.
Hold back the spring slide and pull the battery out.
2 участников успешно повторили данное руководство.
