Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Sometimes the hard drive is corrupt, or you want to install a new one. This guide will show you how to take out a hard drive and replace.
Выберете то, что вам нужно
Lay laptop on it's face and remove the two #1 Phillips screws in the back of the black plastic panel with a raised center.
Carefully lift the panel using the thumb slot on the side closest to you while the battery is pointed out.
Place two fingers gently on the hard drive.
Slide it back to the left.
Lift the drive by the two corner tabs making sure not to touch the metel
2 участников успешно повторили данное руководство.
