Введение
In this guide you will learn how to remove the battery of your Toshiba Satellite U925T-S2120. If your battery is broken, you may need to replace it. Before beginning this guide you should have all tools that are listed.
Выберете то, что вам нужно
Use a Philips #1 screwdriver to remove the nine 5.8 mm screws highlighted.
Remove the two 6.8 mm screws. Set aside.
Remove the back panel by inserting the plastic opening tool into the seam of the laptop and pushing downwards.
Remove the black cable from the connector. Pull in the same direction as the black wiring runs.
4 участников успешно повторили данное руководство.
