Введение
In this guide you will learn how to remove the fan of your Toshiba Satellite U925T-S2120. If your fan is broken, you may need to replace it. Before beginning this guide you should have all required tools that are listed.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to remove the 9 rubber grip pads on the back panel of the laptop.
Use a PH1 screwdriver to remove the nine 5.8 mm screws.
Unscrew the two 6.8 mm screws. Set all screws aside.
Remove the back panel by inserting the plastic opening tool into the seam of the laptop, and pushing the opening tool downwards.
Pull the cables away from the two connectors in the same direction as the individual wires are running.
Еще один человек закончил это руководство.
