Введение
Your hard drive stores and retrieves all memory on your laptop. In this guide you will learn how to remove the hard drive of your Toshiba Satellite U925T-S2120. If your hard drive is broken, you may need to replace it. Prior to beginning this guide you should have all required tools that are listed.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to pinch and pull out and remove the nine rubber gripper pads on the back panel of the laptop. Set aside.
Unscrew nine 5.8 mm screws using a PH1 screwdriver and turning clockwise.
Use the same screwdriver to remove the two 6.8 mm screws.
Remove the back panel open by inserting the plastic opening tool into the seam of the laptop and pushing downwards. Repeat the motion around the perimeter of the device.
Hold back the orange plastic strip with one hand
Use a PH1 screwdriver to unscrew the two 3.4 mm screws by turning clockwise.
Lift the silver flap away from the hard drive.
Gently pinch and lift out the hard drive with your thumb and pointer finger.
2 человек успешно провели ремонт по этому руководству.
