Введение
In this guide you will learn how to remove the heat sink of your Toshiba Satellite U925T-S2120. If your heat sink is clogged or broken, you may need to replace it. Before beginning this guide you should have all required tools that are listed.
Выберете то, что вам нужно
Unscrew the nine 5.8 mm screws using a PH1 screwdriver.
Unscrew the two 6.8 mm screws. Set all screws aside.
Remove the back panel by inserting the plastic opening tool into the seam of the laptop and pushing the opening tool downwards.
Еще один человек закончил это руководство.
