Введение
If your computer is slow, crashing during normal operation or will not boot up, then the RAM might need to be replaced. This guide offers instructions for RAM removal and replacement.
Выберете то, что вам нужно
Unplug the laptop and turn it off.
Flip the laptop upside down.
Locate the battery on the underside of the laptop.
Slide the battery away from the laptop.
Locate the serial number on the battery to order a replacement.
Remove the RAM.
Carefully undo the clips on either side of the top RAM.
Remove the chip by pulling it out of its slot.
Repeat until you have removed the chip that you want to replace.
Еще один человек закончил это руководство.
