Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The keyboard needs to be removed to access everything (hard drive, optical drive, RAM, motherboard).
Запчасти
Детали не указаны.
  1. With the battery away from you, slide the locking clips out. The left clip stays, the right clip is spring loaded.
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Use a spudger to carefully pry up the keyboard screw cover.
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Remove the two screws securing the keyboard to the chassis.
    • Remove the two screws securing the keyboard to the chassis.
  4. Carefully tilt the keyboard towards you and release the ribbon cables.
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
Заключение
2 участников успешно повторили данное руководство.
Tyler
Участник с: 19.06.2012
4 689 Репутация
Автор 16 руководств
Команда
TechForce Участник TechForce
Business
2 членов
Автор 18 руководств
Комментариев: 2
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
Kathleen T - Ответить
If I remember correctly, this keyboard is backlit. Most likely the copper cable is for the backlit power. A new keyboard would need to be purchased to fix it.
Tyler - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 512
