Введение
The keyboard needs to be removed to access everything (hard drive, optical drive, RAM, motherboard).
Выберете то, что вам нужно
With the battery away from you, slide the locking clips out.
Slide the battery away from you.
Carefully tilt the keyboard towards you and release the ribbon cables.
Use a spudger if needed to release the latch. The latch slides out.
The keyboard is now free and can be set aside.
2 участников успешно повторили данное руководство.
2 Комментариев
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
