Выберете то, что вам нужно
With the battery away from you, slide the locking clips out.
Slide the battery away from you.
Carefully tilt the keyboard towards you and release the ribbon cables.
Use a spudger if needed to release the latch. The latch slides out.
The keyboard is now free and can be set aside.
Flip the laptop over so the bottom is facing up.
Using a spudger, remove the seven rubber inserts.
Stand the laptop up on end.
Remove the two rubber inserts from the back of the laptop. One insert is on each side of the laptop.
Carefully work a spudger in the crack at the back of the laptop and separate the small rubberized section from the bottom of the laptop.
The bottom of the laptop is now ready to lift off.
Carefully work a spudger around the seam of the laptop separating the bottom from the rest of the laptop.
Use a spuder to carefully disconnect the wire from the motherboard. Once this is free the bottom will come off.
Locate the hard drive.
Remove the three screws.
Slide the hard drive out away from the motherboard connector.
Once the hard drive is disconnected it lifts out.
Locate the wireless card.
Remove the white antenna lead.
Remove the single screw.
Lift the card up from the edge with the screw, and pull out.
Locate optical drive
Remove the three screws securing the optical drive.
Slide the optical drive away from the motherboard, and carefully lift up.
Carefully flip the laptop rightside up and open the lid.
Disconnect the cables from the motherboard.
Close the laptop lid, and flip back over so you see the motherboard.
Disconnect all cables from the motherboard.
This wire holder is stuck on with a little glue and should lift right off.
Remove the heatsink screws. And lift up the heatsink.
Remove the three screws holding the motherboard to the chasis.
Lift up on ribbon cable latch.
Gently disconnect ribbon cable from motherboard.
The motherboard should lift out.
3 Комментариев
This guide could really use an explanation of how to disconnect the different types of cables from the motherboard. In particular, the descriptions for steps 16 and 17 are completely inadequate to me.
Also, to replace the motherboard you must remove the CPU and RAM from the motherboard, so they can be connected to the new one. This guide does not cover that.
gitm -
Anther important omission is the data connection to the card reader, which needs to be disconnected in Step 11 (this is one of two connections between the motherboard and the bottom of the case).
gitm -
