Запчасти
No parts specified.
  1. With the battery away from you, slide the locking clips out. The left clip stays, the right clip is spring loaded.
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Use a spudger to carefully pry up the keyboard screw cover.
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Remove the two screws securing the keyboard to the chassis.
    • Remove the two screws securing the keyboard to the chassis.
  4. Carefully tilt the keyboard towards you and release the ribbon cables.
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
  5. Remove the five black screws
    • Remove the five black screws
    • Remove the one silver screw
  6. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  7. Flip the laptop over so the bottom is facing up.
    • Flip the laptop over so the bottom is facing up.
    • Using a spudger, remove the seven rubber inserts.
    • The feet only go in one location on the bottom of the laptop, so save yourself some time and track where they go.
  8. Remove the six silver screws.
    • Remove the six silver screws.
    • Remove the one black screw.
  9. Stand the laptop up on end. Remove the two rubber inserts from the back of the laptop.  One insert is on each side of the laptop.
    • Stand the laptop up on end.
    • Remove the two rubber inserts from the back of the laptop. One insert is on each side of the laptop.
  10. Remove the two screews. Remove the two screews.
    • Remove the two screews.
  11. Carefully work a spudger in the crack at the back of the laptop and separate the small rubberized section from the bottom of the laptop.
    • Carefully work a spudger in the crack at the back of the laptop and separate the small rubberized section from the bottom of the laptop.
  12. Remove the four screws.
    • Remove the four screws.
    • Disconnect the black wireless antenna lead.
  13. The bottom of the laptop is now ready to lift off.
    • The bottom of the laptop is now ready to lift off.
    • Carefully work a spudger around the seam of the laptop separating the bottom from the rest of the laptop.
    • There is a data connection at the front of the laptop that needs to be disconnected.
    • Use a spuder to carefully disconnect the wire from the motherboard. Once this is free the bottom will come off.
  14. Locate the wireless card. Remove the white antenna lead.
    • Locate the wireless card.
    • Remove the white antenna lead.
    • Remove the single screw.
    • Lift the card up from the edge with the screw, and pull out.
Заключение
Tyler
Участник с: 19.06.2012
4 240 Репутация
Автор 16 руководств
Команда
TechForce Member of TechForce
Business
2 членов
Автор 18 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 135
