Введение
If you need to replace the RAM stick, follow this guide. The RAM stick can be accessed from the bottom of the computer. To replace this part, you will need a Phillips 0 screw driver and a plastic prying tool.
Выберете то, что вам нужно
Remove the battery by sliding the tabs to the left.
Use the spudger to lift the battery out.
Use the Phillips head screw driver to remove the screw holding the back plate on.
Use the spudger to remove the back plate.
Unlock the RAM by lightly pushing the two metallic holding arms away from the RAM stick.
Grab the RAM stick by the protruding edge.
Pull the RAM stick towards the right to remove.
