Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If a fan stops working all together on this device, then replacing it can be a good way to save money over buying a new projector. This guide will show how to get to and replace this part.
Выберете то, что вам нужно
Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
Remove cables from the power supply board.
Remove the screws located around the board to un-mount it.
Remove the power board to reveal the bottom two screws to the fan.
Unscrew the fan and replace it with an equivalent one.
