Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If you notice that your bicycle tire is flat and re-inflating does not work or has a slow leak, you need to replace your bicycle tube inside the tire. This guide will demonstrate the process and steps required to fix a worn or punctured bike tube on a Trek 800 model bicycle.
Выберете то, что вам нужно
Disengage the rear brake before you remove the rear wheel.
Pinch the arms to compress the brake cable.
Pull the cable out of the lever and it will fully release.
Locate the skewer on the center of the wheel attached to the bicycle frame slots.
Turn the skewer lever away from the bicycle.
Turn the skewer cap counter clockwise.
Once it is loose enough, you can pull the tire off, but do not pull it yet entirely off.
Pull the tire and the rim off of the bike.
Pinch the tire and separate from the rim.
Pull out the punctured tube from the tire and replace with the new tube.
Alternatively you might want to patch your tube's puncture.
Put the tire with the new tube inside back on the rim.
Make sure the hole in the rim lines up with the valve on the tube properly.
Re-attach the rim to the bike frame in reverse order of removal.
Make sure the chain aligns with the sprocket.
Slide the quick-release skewer into the slots in the bike frame.
Make sure the skewer is completely inserted into the frame slots before tightening.
Rotate the skewer cap clockwise and ensure a snug contact between the skewer caps and the frame slots.
Rotate the skewer lever towards the bicycle frame.
Insert the tire pump head into the valve, and lock with lever on the pump head.
If all of your steps were completed correctly you should be free to ride. Enjoy.
Один комментарий
Thanks for providing these instructions. But I think the most difficult step (getting the tire off the rim) should be explained in more detail.
