Введение
You may need to replace the light mount on your bicycle because the light has burned out or you require a brighter light. This guide shows the proper steps to install a replacement Light Mount for a Trek 820 (or similar) bicycle. No tools are necessary for this easy repair.
Выберете то, что вам нужно
Clean the area where the light mount will be installed with a soft cloth.
Placing the light mount close to the center stem.
Remove the strap from the light mount fitting.
Stretch the strap clockwise around the handlebars.
Place the fastening screw in the rear screw port on the light mount.
Twist the screw clockwise using your hands until fully fastened.
Now you have a light mount ready for safer night rides on your Trek bicycle!
