Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Begin loosening the tire by turning the quick release handle.
Gripping the rear derailleur, pull the arm back, away from the front of the bike.
Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
There should be enough slack, in the chain, at this point to remove the tire from the bike.
Remove the tire from the bike.
Place the tire flat on the ground making sure the disk is facing you.
Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws.
After all of the screws have been removed, take the disk and pull it away from the tire.
