Введение
Every kendama player has experienced a broken string or a knot coming undone. It can be frustrating dealing with frayed strings and lost beads. These steps should quickly get your kendama back into its prime condition.
Выберете то, что вам нужно
Видео обзор
Remove the damaged string and the small plastic bead completely, using scissors if necessary.
Begin by inserting one end of the new string straight through the hole at the crosspiece.
Flip the kendama over to the other side, so that the big cup is now on the left-hand side.
Pull the end of the string until it extends about an inch out of the hole. This will be used to tie the knot.
To tie the knot, begin by taking the inch of extended string and making a small loop.
Put the tip of the string through the loop.
Put the tip of the string through the loop a second time to strengthen the knot. Pull the knot tight.
Now, we will attach the ball.
Begin by placing the ball upright, with the small hole on top.
Insert the free end of the string through the small hole, and continue pushing it through until it comes out the big hole on the bottom.
Thread the free end of the string through a small plastic bead, and allow the bead to slide down into the ball.
Now, with about an inch of string extending out from the big hole, we will tie a knot on the free end of the string, just like what was done in step 5.
The kendama is ready to go!
Strings are bound to become damaged through excessive kendama use. However, these steps should save you plenty of time and frustration when repairing your beloved kendama.
For replacement strings visit: https://shop.kendamausa.com/collections/...
Один комментарий
This tutorial is awesome, waiting for the next tutorial on how to be 99 parsing warlock.
