Введение
If your tablet's battery no longer holds a charge, this guided will show you how to replace it with a new one.
Выберете то, что вам нужно
Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
Use the soldering iron to remove the two metal ends that connect the battery to the motherboard.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Use the plastic card to pry the battery away from the device.
2 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
where can i buy a battery replacement? can it work without a battery?
