Trio AXS 3G Screen Replacement
Выберете то, что вам нужно
  1. Trio AXS 3G Screen Replacement, Back Case: шаг 1, изображение 1 из 1
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
  2. Trio AXS 3G Screen Replacement: шаг 2, изображение 1 из 2 Trio AXS 3G Screen Replacement: шаг 2, изображение 2 из 2
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
  3. Trio AXS 3G Screen Replacement: шаг 3, изображение 1 из 1
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
  4. Trio AXS 3G Screen Replacement, Screen: шаг 4, изображение 1 из 1
    • The motherboard and battery will have to be removed to expose the metal panel underneath.
  5. Trio AXS 3G Screen Replacement: шаг 5, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    • Use the plastic card to pry the battery away from the device.
    • The battery is attached to the tablet by glue.
  6. Trio AXS 3G Screen Replacement: шаг 6, изображение 1 из 1
    • Peel off the battery from the device and set aside.
    • The battery is connected to the motherboard by two wires. Be careful not to sever the connection.
  7. Trio AXS 3G Screen Replacement: шаг 7, изображение 1 из 1
    • Using a #000 screwdriver, unscrew the five 4mm and 3 mm screws connecting the top portion of the motherboard to the device.
  8. Trio AXS 3G Screen Replacement: шаг 8, изображение 1 из 1
    • Disconnect the silver tape that attaches the motherboard to the metal panel.
  9. Trio AXS 3G Screen Replacement: шаг 9, изображение 1 из 1
    • Disconnect the ribbon from the bottom portion of the motherboard.
  10. Trio AXS 3G Screen Replacement: шаг 10, изображение 1 из 1
    • Remove the motherboard and set aside.
  11. Trio AXS 3G Screen Replacement: шаг 11, изображение 1 из 1
    • The smaller portion of the motherboard is located at the bottom with the speaker.
    • Using a #000 screwdriver, unscrew the three 3 mm screws that fasten the smaller segment of the motherboard to the tablet.
  12. Trio AXS 3G Screen Replacement: шаг 12, изображение 1 из 2 Trio AXS 3G Screen Replacement: шаг 12, изображение 2 из 2
    • Located towards the bottom, carefully remove the yellow film.
  13. Trio AXS 3G Screen Replacement: шаг 13, изображение 1 из 1
    • Gently disconnect the small ribbon found underneath the film.
  14. Trio AXS 3G Screen Replacement: шаг 14, изображение 1 из 1
    • There is another connection found underneath this portion of the motherboard.
    • Lifting up the motherboard, disconnect the second ribbon found underneath.
  15. Trio AXS 3G Screen Replacement: шаг 15, изображение 1 из 1
    • Unscrew the two 4 mm #000 screws.
  16. Trio AXS 3G Screen Replacement: шаг 16, изображение 1 из 1
    • Remove the speaker and bottom portion of the motherboard.
  17. Trio AXS 3G Screen Replacement: шаг 17, изображение 1 из 1
    • At this stage, almost all inside components should be removed (as shown).
    • Using a screwdriver size #000, remove the four 4 mm screws found at each corner of the metal panel if you haven't gotten them already.
  18. Trio AXS 3G Screen Replacement: шаг 18, изображение 1 из 3 Trio AXS 3G Screen Replacement: шаг 18, изображение 2 из 3 Trio AXS 3G Screen Replacement: шаг 18, изображение 3 из 3
    • Use the plastic card to separate the metal panel from the screen component.
  19. Trio AXS 3G Screen Replacement: шаг 19, изображение 1 из 1
    • Separate memory card from screen.
  20. Trio AXS 3G Screen Replacement: шаг 20, изображение 1 из 2 Trio AXS 3G Screen Replacement: шаг 20, изображение 2 из 2
    • Use the plastic card to separate screen component from front panel.
  21. Trio AXS 3G Screen Replacement: шаг 21, изображение 1 из 1
    • Use the plastic card to separate the glass from the front panel.
    • Once the glass is removed, the new glass can be fitted to the front panel.
Заключение
Michaela Causey
Участник с: 09/20/17
328 Репутация
Автор 3 руководств
Команда
University of North Texas, Team S7-G6, Thomas Fall 2017 Участник University of North Texas, Team S7-G6, Thomas Fall 2017
UNT-THOMAS-F17S7G6
3 членов
Автор 12 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 1,114
