Введение
This guide will describe how to remove the back cover to your Trio STEALTH-9 and replace a new one in its place. This process should not take too long and will only require the removal of a few screws and a careful hand with the plastic shell.
Выберете то, что вам нужно
Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
To reassemble your device, follow these instructions in reverse order with your replacement cover!
2 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Tengo.una y costo tiene el.displey
Deseo.saber el.c
