Trio STEALTH-9 Battery Replacement
Выберете то, что вам нужно
  1. Trio STEALTH-9 Battery Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Remove the two Phillips #00 screws on the side of the tablet.
    Спросите у FixBot
    Добавить комментарий
  2. Trio STEALTH-9 Battery Replacement: шаг 2, изображение 1 из 1
    • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
    Спросите у FixBot
  3. Trio STEALTH-9 Battery Replacement: шаг 3, изображение 1 из 1
    • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
    Спросите у FixBot
  4. Trio STEALTH-9 Battery Replacement: шаг 4, изображение 1 из 1
    • Remove the back cover of the tablet to reveal the internals.
    • To replace, pinch each of the ends together until all four sides are closed.
    Спросите у FixBot
  5. Trio STEALTH-9 Battery Replacement, Battery: шаг 5, изображение 1 из 1
    • With the cover removed, slowly pull the electrical tape away as shown.
    Спросите у FixBot
  6. Trio STEALTH-9 Battery Replacement: шаг 6, изображение 1 из 1
    • Slowly pull the Battery away from the tablet frame.
    Спросите у FixBot
  7. Trio STEALTH-9 Battery Replacement: шаг 7, изображение 1 из 1
    • Prepare your Soldering Iron and Removal Tools.
    • Contact the iron with each of the battery leads, and pull the lead away from the board.
    • Remove any excess solder as needed.
    Спросите у FixBot
  8. Trio STEALTH-9 Battery Replacement: шаг 8, изображение 1 из 1
    • To replace your battery, you must reinsert the Battery leads into the Motherboard, being sure that the Red wire goes into the + (positive) terminal and the Black wire goes into the - (negative) terminal.
    • Apply heat and solder to each lead individually.
    • Remove any excess solder if flooding occurs.
    Спросите у FixBot
Заключение
To replace the battery, you must re-solder the leads on the battery into the motherboard. You MUST make sure that the leads were in the correct order as when you started.
[deleted]
Участник с: 01/29/15
415 Репутация
Автор 3 руководств
1 Комментарий к руководству
Is it possible that the wiring to the battery just became loose and I could use these same directions and reconnect or solder (or do both?) The existing battery ?
Jessie ussery - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 26
За всё время: 1,832
