Введение
This guide should not be too difficult, as there isn't really a need to use any soldering/desoldering tools to take apart anything. You will have to still be careful about some of the cables within the device though.
Выберете то, что вам нужно
Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
Remove the #00 Screw holding down the Camera mount, then remove the Camera mount.
Detach the Camera's ribbon cable from the Motherboard using your fingernail or a plastic opening tool.
Remove the camera from the frame and replace as needed.
