Trio Stealth G2 Hype Battery Replacement
Выберете то, что вам нужно
  1. Trio Stealth G2 Hype Battery Replacement, Back Panel: шаг 1, изображение 1 из 2 Trio Stealth G2 Hype Battery Replacement, Back Panel: шаг 1, изображение 2 из 2
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Battery Replacement: шаг 2, изображение 1 из 1
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Battery Replacement: шаг 3, изображение 1 из 3 Trio Stealth G2 Hype Battery Replacement: шаг 3, изображение 2 из 3 Trio Stealth G2 Hype Battery Replacement: шаг 3, изображение 3 из 3
    • Remove the speakers by using your hand to entirely disconnect the back cover.
  4. Trio Stealth G2 Hype Battery Replacement, Speakers: шаг 4, изображение 1 из 2 Trio Stealth G2 Hype Battery Replacement, Speakers: шаг 4, изображение 2 из 2
    • Carefully peel the tape holding down the wires connected to the speaker.
  5. Trio Stealth G2 Hype Battery Replacement: шаг 5, изображение 1 из 1
    • In order to replace the speakers after they are removed, you must solder the wires back onto the motherboard.
    • The red wire must be soldered onto the "+" terminal while the black wire must be terminal must be soldered onto the "-" terminal.
    • Pull the speaker and wires from the motherboard.
  6. Trio Stealth G2 Hype Battery Replacement, Battery: шаг 6, изображение 1 из 2 Trio Stealth G2 Hype Battery Replacement, Battery: шаг 6, изображение 2 из 2
    • While holding the mother board down, slowly remove the battery from tape on the back of the screen.
    • Make sure to keep all wires attached for now.
  7. Trio Stealth G2 Hype Battery Replacement: шаг 7, изображение 1 из 1
    • In order to replace the battery once the wires are removed, you will need to solder the wires of the new battery onto the motherboard.
    • The red wire must be soldered to the "+" terminal while the black is soldered to the "-" terminal.
    • Pull the wires off the motherboard.
Заключение
2 участников успешно повторили данное руководство.
Thomas Lichtenberger
Участник с: 01/21/15
459 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 4-4, Brown Winter 2015 Участник USF Tampa, Team 4-4, Brown Winter 2015
USFT-BROWN-W15S4G4
3 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 2,295
