Введение
The back panel assembly is an important part of the device as it protects all of the internal components of the tablet.
The disassembly is very simple and requires only a plastic opening tool. The latches keeping the back panel attached to the front casing can sometimes be a little difficult to separate, so don't be afraid to use some force.
Выберете то, что вам нужно
Use a plastic opening tool to gently pry the back panel assembly apart from the front casing.
Start on one edge of the device by inserting the plastic opening tool between the back panel and the front casing using a gentle rocking motion.
Once you have successfully separated one edge of the back panel from the front casing, slide the plastic opening tool along the other edges to detach them as well.
The plastic volume button cover may fall out when you remove the back panel. Set it aside.
Еще один человек закончил это руководство.
