Trunk LED Tailgate Strip Light Installation
Выберете то, что вам нужно
  1. Trunk LED Tailgate Strip Light Installation, Cleaning: шаг 1, изображение 1 из 2 Trunk LED Tailgate Strip Light Installation, Cleaning: шаг 1, изображение 2 из 2
    • Thoroughly clean the surface where you'll be applying the trunk LED tail gate lamp.
    • Use soap and water to scrub the area clean since that place is normally dirty.
  2. Trunk LED Tailgate Strip Light Installation, Mounting time: шаг 2, изображение 1 из 2 Trunk LED Tailgate Strip Light Installation, Mounting time: шаг 2, изображение 2 из 2
    • Carefully measure beforehand where you're going to attach the LED strip so it looks even.
    • The LED tailgate strip is designed to be a little bit shorter than the trunk tailgate.
    • Straighten the LED strip and peel adhesive.
    • OPTIONAL: The package includes 4 mounting brackets with screws. You can use these to further secure the LED tailgate lights.
  3. Trunk LED Tailgate Strip Light Installation, Wire tapping: шаг 3, изображение 1 из 3 Trunk LED Tailgate Strip Light Installation, Wire tapping: шаг 3, изображение 2 из 3 Trunk LED Tailgate Strip Light Installation, Wire tapping: шаг 3, изображение 3 из 3
    • Tap reverse light wire.
    • You will need to remove either side of the tail light to locate the reverse light.
    • Use a T-tap to tap the reverse light wire from the tailgate LED strip to positive.
  4. Trunk LED Tailgate Strip Light Installation, Find the connector: шаг 4, изображение 1 из 2 Trunk LED Tailgate Strip Light Installation, Find the connector: шаг 4, изображение 2 из 2
    • This is the trailer light connector. You can see: ground, brake, left signal, right signal - plug that into stock trailer light connector.
    • You will find the trailer light connector near the tow hitch.
  5. Trunk LED Tailgate Strip Light Installation, Test and enjoy: шаг 5, изображение 1 из 3 Trunk LED Tailgate Strip Light Installation, Test and enjoy: шаг 5, изображение 2 из 3 Trunk LED Tailgate Strip Light Installation, Test and enjoy: шаг 5, изображение 3 из 3
    • Hide the wires or zip-tie them.
    • Check the trunk LED tailgate lamp to make sure everything works.
Заключение
You're now on your way to being the coolest truck on the road with your new trunk LED tailgate strip lights!
5 участников успешно повторили данное руководство.
Eric Wu
Участник с: 01/21/15
3 357 Репутация
Автор 23 руководств
21 Комментариев
Should my light bar come on with my headlights they worked without the headlights but when I turn headlights on they don't work what's wrong
Anthony Carter - Ответить
did you get a answer to your problem because I'm having the same problem
marshallsdawgs07 -
Anyone have the answer to this problem yet?
Trevor G -
I'm having the same problem!
Richie - Ответить
I bought a led third brake below the tailgate and i have five wires on the led light.what is the wiring diagram for it
Spencer Sherrod - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 54
За всё время: 41,498
