Запчасти
No parts specified.
  1. Flip over the controller. Then, unscrew the 7 screws holding it together.
    • Flip over the controller.
    • Then, unscrew the 7 screws holding it together.
    • There are no screws hiding under the sticker, so there is no need to rip it off or punch a hole in it (like i tried to do in a previous attempt)
    • After removing the screws, just pull the back off of the controller. There aren't any cables attached to it.
  2. First, unplug the battery connector Then, undo the 8 clips that hold the board to the front casing with the flathead driver.
    • First, unplug the battery connector
    • Then, undo the 8 clips that hold the board to the front casing with the flathead driver.
    • For the lower clips, you might need a slightly bigger flathead.
    • After that, just lift the board up.
    • Be careful not to break the wires that go to the vibration motors, as they are soldered to the board.
    • To remove the vibration motors, just pull them out, being careful not to break the wires.
  3. Remove the screws holding the D-pad and buttons to the front case, carefully prying them out with your flathead. To remove the shoulder buttons, just pull them out.
    • Remove the screws holding the D-pad and buttons to the front case, carefully prying them out with your flathead. To remove the shoulder buttons, just pull them out.
    • Unfortunately, the clear lenses through which the status LEDs shine are glued onto the case and are not removable.
  4. You now have a fully disassembled controller, ready to be repaired or modified
    • You now have a fully disassembled controller, ready to be repaired or modified
Заключение
3 участников успешно повторили данное руководство.
niccotaglia
Участник с: 25.02.2016
223 Репутация
1 Guide authored
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 59
За всё время: 1,921
