Введение
The motherboard is the central processing unit for the keyboard. This guide will help you replace the motherboard in your keyboard. You will need plastic opening tools, and a screw driver with a J1 bit.
Выберете то, что вам нужно
Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case.
The space, +, enter, shift, insert, and backspace keys all have metal parts which might make it a little harder to remove.
Now that the motherboard has been removed from the keyboard, you can put a new motherboard in place of your broken one.
