Tungsten E Disassembly
Выберете то, что вам нужно
  1. Tungsten E Disassembly, Tungsten E Disassembly: шаг 1, изображение 1 из 2 Tungsten E Disassembly, Tungsten E Disassembly: шаг 1, изображение 2 из 2
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Tungsten E Disassembly: шаг 2, изображение 1 из 3 Tungsten E Disassembly: шаг 2, изображение 2 из 3 Tungsten E Disassembly: шаг 2, изображение 3 из 3
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
    I think it's better to open from the right, not the left. The right will separate if you lever the metal back to the outside and push the plastic to the inside. The lft is more like a inge and would damage more easily.
    Just my $0.02.
    Yishai Sered - Ответить
  3. Tungsten E Disassembly: шаг 3, изображение 1 из 2 Tungsten E Disassembly: шаг 3, изображение 2 из 2
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Tungsten E Disassembly: шаг 4, изображение 1 из 2 Tungsten E Disassembly: шаг 4, изображение 2 из 2
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Tungsten E Disassembly: шаг 5, изображение 1 из 3 Tungsten E Disassembly: шаг 5, изображение 2 из 3 Tungsten E Disassembly: шаг 5, изображение 3 из 3
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Tungsten E Disassembly: шаг 6, изображение 1 из 1
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
Заключение
Kevin Hom
Участник с: 01/21/10
103 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 13-22, Maness Winter 2010 Участник Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 членов
Автор 4 руководств
Один комментарий
How does one unplug the battery?
dlcatftwin - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 7,788
