Введение
The slide adjustment lets you fit the headphones to the size that is most comfortable. To replace slide adjustment follow this guide.
Выберете то, что вам нужно
Insert the plastic opening tool into the gap between the fabric and the plastic.
Make sure you have a firm grip, use the plastic opening tool to pry the two plastic pieces apart.
You should have two plastic pieces removed at the end. Replace them with new ones and reassemble.
