Введение
If you're experiencing poor sound quality, you might need or want to replace your speaker. This guide shows the steps necessary to replace the speaker.
Выберете то, что вам нужно
Remove the ear padding by separating the fabric piece from the plastic headphone piece.
The leather padding will slide off the plastic piece holding it in place. Don't be afraid to pull with a little force.
Use a Philips head screwdriver to remove the speaker cover.
Be careful the speaker is attached to the chip inside by wires.
The recommended screwdriver bit size is a PH 0.
Once the speaker cover is removed, the wires can be cut or de-soldered.
Remove the speaker.
Insert the new speaker
Еще один человек закончил это руководство.
Один комментарий
what speaker can i use as a replacement and where can I buy one?
