Введение
The windscreen is designed to prevent dust and moisture from getting into the microphone. It is held onto the microphone by a single 0.4 cm long Phillips head screw attached by a mounting bracket. Due to its fragile design, the windscreen can easily be torn, but it can quickly be replaced with the help of this guide.
Выберете то, что вам нужно
The microphone is a separate piece. So, unplug it from the headset.
Using a Philips #0 screwdriver, unscrew the 4-mm-long screw that attaches the windscreen to the microphone.
Now that the screw is removed, remove the slim metal plate at the base of the windscreen by gently pulling on the plate.
Then slide the windscreen off of the microphone.
