Введение
If your microphone does not work after troubleshooting with our guides it may need to be replaced. This guide will show the user how to remove a broken microphone and replace it with a new microphone.
Выберете то, что вам нужно
Use your fingers to peel off ear cushion by pinching and pulling off the leather.
Use the Philips #00 head screwdriver to remove three screws around the speaker (9/32 in length, 1/8 inch head)
The housing will comes loose. Take note of position of the wires.
Remove the 9/32 inch screw with a Philips 2 screwdriver to gain access to microphone.
Apply heat to the circled wires on the circuit board with a heat gun.
Insert the new microphone and solder the wires into the correct positions.
Pull the excess microphone wire back into the speaker housing.
Use the Philips #2 screwdriver to replace the screw and fix the microphone.
Position the speaker on the headset so that the screw holes line up. It should click into place.
Screw in the 3 screws with the 00 Philips head screwdriver.
Place the new cushion against speaker and wrap the leather around the plastic. Do this by working around the cushion to get all of the leather around the plastic.
Use the plastic opening tool to tuck excess leather inside the headset.
2 участников успешно повторили данное руководство.
3 Комментариев
i need the cable for my px 24 it broke in my phone how do i get a new cable to fix my px 24 headset
