Введение
The micro-USB port is located under a rubber cover on the bottom of the UE Boom 2 speaker. Replacing this part requires the removal of the D-ring and rubber port cover, In addition the bottom pad must be removed, which will void the device warranty.
Выберете то, что вам нужно
First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
Remove by twisting in a counter-clockwise motion.
Remove the rubber stripping using a metal spudger.
Work around the edge of the rubber stripping slowly prying up the edge.
On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
Pry up at the location marked, and remove the plastic end cap.
7 участников успешно повторили данное руководство.
6 Комментариев
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
i too am looking to find the replacement part
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
Anyone have the part number to convert it to a USB type c instead of A?
