Выберете то, что вам нужно
There are only 2 screws showing in the photo there will be 3.
Remove these connectors. There is plenty of slack so it's easy.
Squeeze to release.
Pull to release.
Slide tabs open to release
Remove
Lift out from this side. Some jiggling may be in order.
Power & Ground can be disconnected, but it's not necessary.
Remove 2 screws. Lift chip and heatsink away from the main optics unit.
Don't lose the spacer and gasket
Rotate ZIF Lock cam to remove chip.
You can see the mirrors that have seized up.
Pins are keyed so you it's hard to screw up.
Rotate cam lock back to locked position.
Snug up your screws.
