UP! Plus 2 Spool Holder Replacement
Выберете то, что вам нужно
  1. UP! Plus 2 Spool Holder Replacement, 3D print replacement spool holder: шаг 1, изображение 1 из 1
    • Before your spool holder breaks, 3D print a replacement to have on hand. If you didn't preemptively print a replacement you can still print without a spool holder. Just find some way of holding the spool so that it can rotate as the filament gets pulled off.
    • Download the file for a new spool holder here
  2. UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: шаг 2, изображение 1 из 3 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: шаг 2, изображение 2 из 3 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: шаг 2, изображение 3 из 3
    • Go to "Maintenance" and tell the printer to withdraw the plastic filament from the extrusion assembly. Finish removing the filament by pulling upwards.
    • Wait for a "beeping" sound before removing filament.
    • Cut off any damaged plastic from the end of the filament.
    • Remove the plastic filament tube from the spool.
  3. UP! Plus 2 Spool Holder Replacement, Remove spool holder: шаг 3, изображение 1 из 3 UP! Plus 2 Spool Holder Replacement, Remove spool holder: шаг 3, изображение 2 из 3 UP! Plus 2 Spool Holder Replacement, Remove spool holder: шаг 3, изображение 3 из 3
    • Remove the spool from the spool holder by lifting it up and taking it off.
    • Put the end of the filament through the hole on the side of the spool to keep it from unraveling.
    • Slide the spool holder upwards, and then pull outwards.
  4. UP! Plus 2 Spool Holder Replacement, Replace spool holder: шаг 4, изображение 1 из 3 UP! Plus 2 Spool Holder Replacement, Replace spool holder: шаг 4, изображение 2 из 3 UP! Plus 2 Spool Holder Replacement, Replace spool holder: шаг 4, изображение 3 из 3
    • Place the new spool holder by pushing it inwards and sliding it down until it locks.
    • Repeat the steps in reverse chronological order to reassemble the printer.
    • The spool should be inserted in way that end of the filament points towards, not away.
Финишная черта
6 участников успешно повторили данное руководство.
valerie boyer
Участник с: 10/12/14
508 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 14-31, Maness Fall 2014 Участник Cal Poly, Team 14-31, Maness Fall 2014
CPSU-MANESS-F14S14G31
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 11
За последние 30 дней: 16
За всё время: 1,216
