Введение
The spool holder is a 3D printed part that holds the filament spool and the feed tube, keeping it stable and secure to the system. Be sure to print a spare spool holder prior to replacement.
Инструменты
No tools required.
Запчасти
  1. Before your spool holder breaks, 3D print a replacement to have on hand. If you didn't preemptively print a replacement you can still print without a spool holder. Just find some way of holding the spool so that it can rotate as the filament gets pulled off.
    • Before your spool holder breaks, 3D print a replacement to have on hand. If you didn't preemptively print a replacement you can still print without a spool holder. Just find some way of holding the spool so that it can rotate as the filament gets pulled off.
    • Download the file for a new spool holder here
  2. Go to "Maintenance" and tell the printer to withdraw the plastic filament from the extrusion assembly. Finish removing the filament by pulling upwards. Wait for a "beeping" sound before removing filament. Cut off any damaged plastic from the end of the filament.
    • Go to "Maintenance" and tell the printer to withdraw the plastic filament from the extrusion assembly. Finish removing the filament by pulling upwards.
    • Wait for a "beeping" sound before removing filament.
    • Cut off any damaged plastic from the end of the filament.
    • Remove the plastic filament tube from the spool.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Remove the spool from the spool holder by lifting it up and taking it off. Put the end of the filament through the hole on the side of the spool to keep it from unraveling. Slide the spool holder upwards, and then pull outwards.
    • Remove the spool from the spool holder by lifting it up and taking it off.
    • Put the end of the filament through the hole on the side of the spool to keep it from unraveling.
    • Slide the spool holder upwards, and then pull outwards.
  5. Place the new spool holder by pushing it inwards and sliding it down until it locks. Repeat the steps in reverse chronological order to reassemble the printer. The spool should be inserted in way that end of the filament points towards, not away.
    • Place the new spool holder by pushing it inwards and sliding it down until it locks.
    • Repeat the steps in reverse chronological order to reassemble the printer.
    • The spool should be inserted in way that end of the filament points towards, not away.
Финишная черта
3 участников успешно повторили данное руководство.
valerie boyer
Участник с: 12.10.2014
469 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 14-31, Maness Fall 2014 Member of Cal Poly, Team 14-31, Maness Fall 2014
CPSU-MANESS-F14S14G31
4 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 12
За всё время: 643
