Введение
Follow this guide to properly replace the logic board.
Выберете то, что вам нужно
Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
Identify the antenna. It is the extendable plastic component pictured here.
Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
Detach the highlighted piece from the logic board using a plastic opening tool.
Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
