Введение
This guide walks you through the steps to replace the external speaker on your phone. You can follow these same steps to check your speaker connection as well.
Выберете то, что вам нужно
Remove the battery cover by pressing and sliding the cover down and off of the phone.
Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
Remove the four 5.0-mm Torx T6 screws from the corners of the black cover.
Remove the 4.0-mm #00 Phillips screw that holds the wireless antenna in place. The antenna does not need to be removed.
Use the spudger and plastic opening tools to apply firm but gentle pressure equally around the outside of the case.
Carefully pry the black portion of the case away from the silver portion.
Using tweezers, pull on the connector or wire in the direction of the wire with gentle pressure to unplug the wire connector from the motherboard.
Press your finger on the speaker from the outside of the housing, and the speaker will come out.
