Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide walks you through the steps to replace the external speaker on your phone. You can follow these same steps to check your speaker connection as well.
  1. Press the on/off button on the top to power the phone off.
    • Press the on/off button on the top to power the phone off.
  2. Remove the battery cover by pressing and sliding the cover down and off of the phone.
    • Remove the battery cover by pressing and sliding the cover down and off of the phone.
  3. Pull the battery removal tab and lift the battery out of the phone. If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up. If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
    • Pull the battery removal tab and lift the battery out of the phone.
    • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
  4. Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment.  Tweezers may be useful to remove the screws.
    • Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
  5. Use firm pressure to carefully pry off the cover with your fingers. Use firm pressure to carefully pry off the cover with your fingers.
    • Use firm pressure to carefully pry off the cover with your fingers.
  6. Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board.  The board is still connected by a connector on the bottom of the board.
    • Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
  7. Gently pry off the camera flash circuit board with the spudger.
    • Gently pry off the camera flash circuit board with the spudger.
  8. Gently pry off the camera with the spudger.
    • Gently pry off the camera with the spudger.
  9. Remove the four 5.0-mm Torx T6 screws from the corners of the black cover.
    • Remove the four 5.0-mm Torx T6 screws from the corners of the black cover.
  10. Remove the 4.0-mm #00 Phillips screw that holds the wireless antenna in place.  The antenna does not need to be removed.
    • Remove the 4.0-mm #00 Phillips screw that holds the wireless antenna in place. The antenna does not need to be removed.
  11. Use the spudger and plastic opening tools to apply firm but gentle pressure equally around the outside of the case. Carefully pry the black portion of the case away from the silver portion. Do not try to remove case completely.  The speaker wire is still connected to the motherboard.
    • Use the spudger and plastic opening tools to apply firm but gentle pressure equally around the outside of the case.
    • Carefully pry the black portion of the case away from the silver portion.
    • Do not try to remove case completely. The speaker wire is still connected to the motherboard.
  12. Using tweezers, pull on the connector or wire in the direction of the wire with gentle pressure to unplug the wire connector from the motherboard.
    • Using tweezers, pull on the connector or wire in the direction of the wire with gentle pressure to unplug the wire connector from the motherboard.
  13. Press your finger on the speaker from the outside of the housing, and the speaker will come out. Press your finger on the speaker from the outside of the housing, and the speaker will come out.
    • Press your finger on the speaker from the outside of the housing, and the speaker will come out.
Заключение
Tyson Janisch
Участник с: 04.06.2013
301 Репутация
Автор 3 руководств
Команда
University of Kentucky Louisville, Team 1-4, Chamberlain Spring 2013 Участник University of Kentucky Louisville, Team 1-4, Chamberlain Spring 2013
LOUISVILLE-CHAMBERLAIN-S13S1G4
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 104
