Ultimate Ears Wonderboom 3 Battery Replacement
Выберете то, что вам нужно
  1. Ultimate Ears Wonderboom 3 Battery Replacement, Speaker Mesh: шаг 1, изображение 1 из 3 Ultimate Ears Wonderboom 3 Battery Replacement, Speaker Mesh: шаг 1, изображение 2 из 3 Ultimate Ears Wonderboom 3 Battery Replacement, Speaker Mesh: шаг 1, изображение 3 из 3
    • To unclip the top of the speaker from the body, insert the metal spudger to the left of the speaker's center. To find the correct position, make sure the pointed end of the spudger is inserted entirely.
    • While in this position, press down and into the speaker to unclip the top. You should feel and hear and audible click.
    • Repeat this on all four sides of the speaker. The speaker's top will snap off when you press down on it, so make sure you hold onto the top so it does not fly off.
  2. Ultimate Ears Wonderboom 3 Battery Replacement: шаг 2, изображение 1 из 1
    • Take the top off of the speaker to reveal the inside of the speaker.
    • Carefully set the top cover to the side and make sure the clear plastic button tabs stay intact.
  3. Ultimate Ears Wonderboom 3 Battery Replacement: шаг 3, изображение 1 из 2 Ultimate Ears Wonderboom 3 Battery Replacement: шаг 3, изображение 2 из 2
    • Take the mesh covering off of the speaker by pressing on the center of the speaker and pulling the mesh upwards.
  4. Ultimate Ears Wonderboom 3 Battery Replacement, Speaker Drivers: шаг 4, изображение 1 из 1
    • Unscrew the four M3 x 6mm Phillips head screws in each corner of the speaker.
  5. Ultimate Ears Wonderboom 3 Battery Replacement: шаг 5, изображение 1 из 1
    • Using the metal spudger, slowly wedge it behind the speaker.
    • Slowly and gently push the spudger forward to dislodge waterproofing adhesive that holds the speaker in place.
    • This step will affect the waterproof quality of the speaker.
  6. Ultimate Ears Wonderboom 3 Battery Replacement: шаг 6, изображение 1 из 1
    • Pull the speaker driver forward to dislodge it from the speaker.
    • Next, turn the speaker driver to where the wires are facing upwards.
  7. Ultimate Ears Wonderboom 3 Battery Replacement: шаг 7, изображение 1 из 1
    • Using the soldering iron, desolder the white and black wires (the 2 connections) at the top of the speaker driver.
  8. Ultimate Ears Wonderboom 3 Battery Replacement, Battery: шаг 8, изображение 1 из 2 Ultimate Ears Wonderboom 3 Battery Replacement, Battery: шаг 8, изображение 2 из 2
    • Locate and unscrew the M3 x 8mm screws found under each of the four speakers.
  9. Ultimate Ears Wonderboom 3 Battery Replacement: шаг 9, изображение 1 из 3 Ultimate Ears Wonderboom 3 Battery Replacement: шаг 9, изображение 2 из 3 Ultimate Ears Wonderboom 3 Battery Replacement: шаг 9, изображение 3 из 3
    • Remove the main center of the speaker, exposing the bottom and the battery.
    • Carefully place the metal spudger under the battery. Being slow yet forceful, push the spudger under the battery and force upwards. This will pry the waterproof adhesive, affecting its ability to be waterproof in the future.
    • Be careful not to puncture the battery when doing this step.
    • Remove the battery from the adhesive and set it aside.
  10. Ultimate Ears Wonderboom 3 Battery Replacement: шаг 10, изображение 1 из 1
    • Using the iFixit Large Needle Nose Pliers, remove the red wire connecter that is attached to the battery.
    • Sometimes there is a little bit of glue on the connecter that can make it difficult to remove.
    • Pull the battery out of the device
Заключение
Madelyn Woodard
Участник с: 01/23/24
659 Репутация
Автор 5 руководств
Команда
Western Carolina University, Team 1-3, Virtue Spring 2024 Участник Western Carolina University, Team 1-3, Virtue Spring 2024
WCU-VIRTUE-S24S1G3
4 членов
Автор 8 руководств
4 Комментарии к руководству
What's the purpose of desoldering in step 7?
Hanning Xu - Ответить
Great - except the unit I'm looking at to replace the battery has 4 clips rather than screws holding the base on - and they won't release! Anyone have a suggestion? Is the base perhaps also hot-glued in place?
Stewart P - Ответить
I thought ifixit had a battery change description for all Wonderboom models - 1,2 and 3. That's what it said on the A1 page after searching.
So does anyone know if the above description (which seems very good) applies to the original UE Wonderboom 1? Please reply direct to: peter@lakesweddingmusic.com if you think you may have a solution - I'd be SO grateful!
Peter Wedding & Party Pianist - Ответить
Does this work in the original Wonderboom?
Pablo Roldán - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 43
За последние 30 дней: 215
За всё время: 3,401
