Ultimate Ears Wonderboom 3 Holding Strap Replacement
Выберете то, что вам нужно
  1. Ultimate Ears Wonderboom 3 Holding Strap Replacement, Speaker Mesh: шаг 1, изображение 1 из 3 Ultimate Ears Wonderboom 3 Holding Strap Replacement, Speaker Mesh: шаг 1, изображение 2 из 3 Ultimate Ears Wonderboom 3 Holding Strap Replacement, Speaker Mesh: шаг 1, изображение 3 из 3
    • To unclip the top of the speaker from the body, insert the metal spudger to the left of the speaker's center. To find the correct position, make sure the pointed end of the spudger is inserted entirely.
    • While in this position, press down and into the speaker to unclip the top. You should feel and hear and audible click.
    • Repeat this on all four sides of the speaker. The speaker's top will snap off when you press down on it, so make sure you hold onto the top so it does not fly off.
  2. Ultimate Ears Wonderboom 3 Holding Strap Replacement: шаг 2, изображение 1 из 1
    • Take the top off of the speaker to reveal the inside of the speaker.
    • Carefully set the top cover to the side and make sure the clear plastic button tabs stay intact.
  3. Ultimate Ears Wonderboom 3 Holding Strap Replacement: шаг 3, изображение 1 из 2 Ultimate Ears Wonderboom 3 Holding Strap Replacement: шаг 3, изображение 2 из 2
    • Take the mesh covering off of the speaker by pressing on the center of the speaker and pulling the mesh upwards.
  4. Ultimate Ears Wonderboom 3 Holding Strap Replacement, Holding Strap: шаг 4, изображение 1 из 2 Ultimate Ears Wonderboom 3 Holding Strap Replacement, Holding Strap: шаг 4, изображение 2 из 2
    • Grabbing the top of the speaker that was removed earlier, remove both of the strap endings that are stuck through as seen above.
    • Feed the strap through the hole and pull it out.
Заключение
Madelyn Woodard
Участник с: 01/23/24
659 Репутация
Автор 5 руководств
Команда
Western Carolina University, Team 1-3, Virtue Spring 2024 Участник Western Carolina University, Team 1-3, Virtue Spring 2024
WCU-VIRTUE-S24S1G3
4 членов
Автор 8 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 27
За всё время: 755
