Ultimate Ears Wonderboom 3 Speaker Drivers Replacement
Выберете то, что вам нужно
  1. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement, Speaker Mesh: шаг 1, изображение 1 из 3 Ultimate Ears Wonderboom 3 Speaker Drivers Replacement, Speaker Mesh: шаг 1, изображение 2 из 3 Ultimate Ears Wonderboom 3 Speaker Drivers Replacement, Speaker Mesh: шаг 1, изображение 3 из 3
    • To unclip the top of the speaker from the body, insert the metal spudger to the left of the speaker's center. To find the correct position, make sure the pointed end of the spudger is inserted entirely.
    • While in this position, press down and into the speaker to unclip the top. You should feel and hear and audible click.
    • Repeat this on all four sides of the speaker. The speaker's top will snap off when you press down on it, so make sure you hold onto the top so it does not fly off.
  2. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement: шаг 2, изображение 1 из 1
    • Take the top off of the speaker to reveal the inside of the speaker.
    • Carefully set the top cover to the side and make sure the clear plastic button tabs stay intact.
  3. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement: шаг 3, изображение 1 из 2 Ultimate Ears Wonderboom 3 Speaker Drivers Replacement: шаг 3, изображение 2 из 2
    • Take the mesh covering off of the speaker by pressing on the center of the speaker and pulling the mesh upwards.
  4. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement, Speaker Drivers: шаг 4, изображение 1 из 1
    • Unscrew the four M3 x 6mm Phillips head screws in each corner of the speaker.
  5. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement: шаг 5, изображение 1 из 1
    • Using the metal spudger, slowly wedge it behind the speaker.
    • Slowly and gently push the spudger forward to dislodge waterproofing adhesive that holds the speaker in place.
    • This step will affect the waterproof quality of the speaker.
  6. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement: шаг 6, изображение 1 из 1
    • Pull the speaker driver forward to dislodge it from the speaker.
    • Next, turn the speaker driver to where the wires are facing upwards.
  7. Ultimate Ears Wonderboom 3 Speaker Drivers Replacement: шаг 7, изображение 1 из 1
    • Using the soldering iron, desolder the white and black wires (the 2 connections) at the top of the speaker driver.
Заключение
Еще один человек закончил это руководство.
Madelyn Woodard
Участник с: 01/23/24
659 Репутация
Автор 5 руководств
Команда
Western Carolina University, Team 1-3, Virtue Spring 2024 Участник Western Carolina University, Team 1-3, Virtue Spring 2024
WCU-VIRTUE-S24S1G3
4 членов
Автор 8 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 13
За последние 30 дней: 60
За всё время: 1,008
