Введение
This guide walks you through how to replace a broken speaker on your UnBranded Tablet.
Выберете то, что вам нужно
Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
As the gaps open, slide the guitar picks along the sides to separate the panels.
Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
Reflow the solder of the black and red wires from the circuit board by using the soldering iron.
