Uniden EXP 371 Antenna Replacement
Выберете то, что вам нужно
  1. Uniden EXP 371 Antenna Replacement, Uniden EXP 371 Teardown: шаг 1, изображение 1 из 1
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Antenna Replacement: шаг 2, изображение 1 из 2 Uniden EXP 371 Antenna Replacement: шаг 2, изображение 2 из 2
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Antenna Replacement: шаг 3, изображение 1 из 2 Uniden EXP 371 Antenna Replacement: шаг 3, изображение 2 из 2
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Antenna Replacement: шаг 4, изображение 1 из 3 Uniden EXP 371 Antenna Replacement: шаг 4, изображение 2 из 3 Uniden EXP 371 Antenna Replacement: шаг 4, изображение 3 из 3
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
  5. Uniden EXP 371 Antenna Replacement, Antenna: шаг 5, изображение 1 из 2 Uniden EXP 371 Antenna Replacement, Antenna: шаг 5, изображение 2 из 2
    • After following the teardown guide. Take the bottom case and locate the antenna at the top of the phone.
    • Lift the bottom of the the antenna with the aid of a tool (these tweezers work well) and push the antenna inside the phone to remove it.
    • To reassemble the phone, follow the steps in the reverse order.
Заключение
Eric Rodrigues
Участник с: 10/16/14
343 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Участник UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,256
